Split braking system issue My '55 Victoria has power disc/drum brakes installed by a previous owner of the car. Recently while driving I noticed the brake pedal was soft and loosing pedal height. I was local, so I drove it home to check the brake fluid and leaks. When opening the reservoir, I noticed brake fluid on the brake warning switch and on the distribution valve and inner fender. The reservoir was empty. I replaced the switch and refilled the reservoir. Now the brake pedal is at normal height and firm. I drove the car yesterday and noticed that increasing brake pedal pressure doesn't increase braking. I wonder if my split system is activated and how to reset it. Thanks for advice you might have.
Re: Split braking system issue Quote:
The MC can be bled on the car if the MC is perfectly level, otherwise bench bleeding. Are you able to post a photo of the install? |
Re: Split braking system issue I agree with K. There’s always a possibility that the fluid got low from pad/shoe wear, but I’d be looking real close for where all the fluid went. A small leak can become a large one suddenly, and that’s a really bad feeling. Been there. Used the t shirt to clean off the seat.
Re: Split braking system issue The brake warning light switch on the distribution valve was leaking. I replaced it.
Re: Split braking system issue Is there a warning lamp (dash) running off the switch? If so, is the lamp illuminated?
Where did you find the switch? Most of these conversions use GM parts. |
Re: Split braking system issue There is no warning light installed. The switch appears to be a simple grounding device for the warning light bulb. I'm going to the shop in a little while to see if switch terminal is grounded.
I ordered the switch on line, it's a GM switch. |
Re: Split braking system issue OK, so it is a GM VALVE.
You can buy a special block-off for the switch if no lamp is desirable. It will trap the pintle inside of the valve from moving. Interested? |
Re: Split braking system issue There is no continuity between the switch terminal and ground. Can I assume that the valve is distributing pressure to front and rear circuits?
In your situation, the PDV is only an expensive DISTRIBUTION BLOCK. Is the PDV free-standing or is it within a COMBINATION VALVE? The tool will prevent the pintle from sliding if a circuit failure. It will also prevent switch failure as has happened here. The PDV is mandated by FEDERAL REGULATION (1967) to alert the driver of a brake failure. It (pintle) does not totally block off the failed braked circuit. That feature is designed within the MC (dual reservoir/piston) itself. Quote:
Re: Split braking system issue Kultulz, My understanding is that the piston, or pintle, that slides within the distribution block blocks (at least partially) the side of the block that is experiencing low pressure. At that time the sliding pintle grounds the switch to illuminate the brake warning light. My thinking is that if the switch isn't grounded, the piston/pintle is centered and allowing flow to both circuits.
I just took the car out for some tests. When I apply the brakes for a casual stop, things seem normal. If I continue to press as in a panic stop or from highway speeds, I get a very hard pedal and no increased braking. If I continue a panic stop, the left rear wheel will slide a little just before the car completely stops. I came home and jacked up front and rear of the right side of the car. I started the car and blocked the brake pedal. I couldn't turn the front or rear wheel with my hands. The power brake chamber seems to work until the brake pedal gets hard, so I don't know if it is faulty or not. |
Re: Split braking system issue 3 Attachment(s)
Without the lamp, it may prove difficult to determine the pintle having moved. Possibly using a test lamp. The procedure to center the pintle (once tripped) usually requires the use of the warning lamp. The fitting (tool) I am describing does not allow the pintle to move. If any of this is not clear, yell at me. I am not proud. See if the attached shows large enough to cipher - |
Re: Split braking system issue Thanks, those illustrations are helpful. They verify that the brake warning switch does provide ground to the lamp.
Re: Split braking system issue 1 Attachment(s)
When the diaphragm fails engine vacuum can suck all the brake fluid out of the master cylinder. It may be part of the problem you're having? . |
Re: Split braking system issue 2 Attachment(s)
What I am trying to say is there is a tool that can be used to eliminate the switch altogether and keep the pintle in a fixed position so this won't happen again. Most likely the switch is an off-shore piece of crap and needs to be eliminated (IMO). The only way to determine if the pintle has moved without the WARNING LAMP feature and without pressure gauges is when bleeding either front and/or rear circuits if the fluid will not expel easily from either circuit (bleeders) |
Re: Split braking system issue Thanks Kultulz, I have pressure to both ends. I have bled the brakes.
Re: Split braking system issue You are more than welcome ...
