The Ford Barn
-   -   Need help with 3-point seat belts (https://www.fordbarn.com/forum/showthread.php?t=350213)
91A-77B 06-24-2025 05:52 PM
I'd appreciate recommendations for front shoulder belts for my 37 Tudor with stock LeBaron Bonney interior. Bad experience with Seat Belt Solutions, who were of no help when I bought a set of theirs in error, and they stone-walled me. I appreciate the help you guys have given me in the past with my many requests.
pbsdaddy 06-24-2025 06:22 PM
Re: Need help with 3-point seat belts
It might be easier to aid with the three point issue if you were to clearly explain how and where you intend to mount the upper guide. Are you going to reinforce the B pillar then weld in a bolt plate, or maybe reinforce the pillar then just weld in a swivel base? How high up, on the pillar are you planning to attach the upper guide? I have a 35 tudor and after reviewing these options, I think reinforcing the floorboard, at the bolt area and going with old style two point belts is the best and most convenient way to do it. Do your front seats flip forward like the 35s? That shoulder belt is going to become a real problem with out a retractor and a lot of extra belt.
paul2748 06-24-2025 07:43 PM
Juliano's Hot Rod Parts (800-300-1932) in CT has kits for the installation of 3 point belts in early Fords and the belts themselves.
farmertom 06-24-2025 08:13 PM
pbsdaddy has some very good points to consider. i used Seatbeltsplus two point lap belts for front bench seat in my '37 fordor. Tom.
91A-77B 06-25-2025 05:11 AM
pbsdaddy makes sense. Yes, I have fold-ahead front seat-backs, and can see the problems they'd create. I had planned to weld plates in b-pillar, but interference with entry/exit from rear would cause problems. Think I'll stick with the lap belts. Thanks!
SoCalCoupe 06-25-2025 08:09 AM
I second this post. Used the juliano's three point belts and installation kit. One of the few projects that went as well and as trouble-free as hoped for. Here's a thread that includes it.
https://www.fordbarn.com/forum/showt...light=Shoulder
