Slant windshield top replacement 1 Attachment(s)
I found a good way to stretch the top material.
Re: Slant windshield top replacement Quote:
Gives a slightly different perspective on "balancing carburetors". |
Re: Slant windshield top replacement interesting......surprised you didnt use cinderblocks!
lol |
Re: Slant windshield top replacement You could also use milk plastic jugs with a handle and fill them with just the right amount of water. Ed
Re: Slant windshield top replacement 2 Attachment(s)
When I put the top on my Victoria, I tacked one side and then pulled the vinyl by hand as I went along nailing it down. The nightmare of this job is bending the reproduction aluminum molding around the back corners with minimal buckling of the molding. A lot of shrinking and tapping was done to take the buckles out the molding.
Re: Slant windshield top replacement I can definitely see where that would get difficult quickly in making those tight bins but it looks like you figured it out and it turned out quite nice!!!
The reproduction aluminum top moldings are hard to find because I no longer make them. To bend the rear top moldings for a sedan that uses aluminum top moldings, please see the FordBarn post titled "Need Help installing & bending the aluminum Trim on a SW Fordor ROOF from 2011". Slant sedans never used aluminum side and rear top moldings; their moldings were steel, but the installation technique is correct for earlier sedans and coupes that used aluminum moldings. The aluminum front molding on a slant sedan or steel back Victoria needs to be installed with the small bump forward. I had 6 varieties of aluminum top moldings extruded for 35 years, and I punched the holes. Aluminum extruders need to extrude a 500-pound billet at a time to make the price affordable, which is a lot of top moldings. The demand for top moldings has dropped off, and the only styles still available are the 1/2 and 5/8 inch wide front moldings, which have a flat bottom. When those are gone, hide-em welt will take their place. |
