The Ford Barn
-   -   40 Radio and Heater Hook-up (https://www.fordbarn.com/forum/showthread.php?t=349944)
Pech33 06-14-2025 07:24 PM
I had my radio upgraded to am/fm/bluetooth inside the stock radio, 6 volt positive ground. It still has just one wire and it’s connected to the left side of the circuit breaker. With the ignition off, the radio works. With the ignition on, it works. Any ideas? I guess I could connect it to the ignition switch. Was it originally connected at the circuit breaker because of suppression issues?
Heater: I have a new harness with the short green wire with a spade end on it. That gets grounded. Where does the long one go? Kube’s book says it goes to the ignition terminal with the red black tracer wire. I’m red green color blind. Does it go on the “com” or “gage” terminal?
Thanks.
Pech33 06-14-2025 07:26 PM
Re: 40 Radio and Heater Hook-up
1 Attachment(s)
Bob C 06-14-2025 09:12 PM
Looking at the wiring diagram the ignition switch only controls power to the ignition coil and instruments.
Terry,OH 06-15-2025 05:17 AM
1 Attachment(s)
The BR wire is the IGN terminal that has the wire going to the ignition resistor, NOT the com or the gauge terminal.
Yes the radio can work with the engine ON or OFF. The left side of the circuit breaker is the battery power side, a convenient source of power before the power goes through the circuit breaker this is why the radio has it's own fuse in the power wire.
glennpm 06-15-2025 06:00 AM
https://www.fordbarn.com/forum/attac...0&d=1749979935
19Fordy 06-15-2025 06:36 AM
Glenn, THANKS for posting that heater switch wiring pictorial.
Kube 06-15-2025 09:12 AM
The heater was wired as depicted in the diagram so it can't operate with the ignition off.
