Mallory points Does anyone have a source for points that work in Mallory distributors?
Re: Mallory points I'd be surprised if Mallory didn't use points from a production car in their distributors. Find out which car and your job should be much easier. Failing that, I'm sure it would be possible to graft in a set of more readily available points. I have just received a deceased estate of stuff from a mechanical workshop. It included about a dozen Bosch (good stuff) points, all the same number. With a little work, I grafted them into an original Model A distributor. I doubt I will wear out one set, let alone that many.
Re: Mallory points What points number?
Re: Mallory points Try member @raybee
I bought some NOS Mallory points from him last year |
Re: Mallory points Quote:
Hasn't been responding since March last year after saying he was moving. |
Re: Mallory points A picture may help
Re: Mallory points 1 Attachment(s)
Re: Mallory points If its a YL series distributor we used to sell Standard Ignition Company part#25042
Re: Mallory points If you cannot post a pic, look on line and see what the part number is and I can refer to it,I have a few mallory sets on hand , you can private message to me and I will see what I have to help you .
Re: Mallory points 2 Attachment(s)
Try FleaBay
I have a very early Mallory that uses the pop out ignition. The points are unobtainable. I bought some Phenolic sheet and a set of V8 points to create a couple sets for this restoration. Luckily there was one set I can copy. |
Re: Mallory points If you have an original set of points the on is stamped on the vert stationary tab
25042 sounds about right for non dual point I forget pn of booster point J |
Re: Mallory points I have some sets of 24205, the horseshoe looking type.
Re: Mallory points A google search shows lots of " Standard Ignition Company part#25042" available, but pricey.
