Lock pins too large for axle? Put a nice new axle in the car and the king pin locking pins seem too large for the holes…bores are less then 9/16. New kingpin set from Synders. Im not sure what to do next. Im surprised the bores are smaller than 9/16…anyone ever encounter this?
Re: Lock pins too large for axle? Are you putting the pins in from the front (as they should be) or from the back?
Re: Lock pins too large for axle? Putting from the front…even with no kingpin in bores are too small…
Re: Lock pins too large for axle? 1 Attachment(s)
The spindle locking pin hole should be reamed .561-.563.
Re: Lock pins too large for axle? Measurement wise,it make no difference if the bolts are put in from the front or back.The hole in the axle is straight,all the way through.But,they need to go in from the front because the nuts are the stops for the spindles.What do the holes in yours actually measure? They should be at Bob's specs.What do your replacement pins measure at?
Re: Lock pins too large for axle? Yes, from the factory, the hole is the same dimension front or back. With each new installation of kingpins, the lock nut on the lock pins is tightened (often severely) against the edge of the hole in the axle. This causes the area at the edge of the hole that the nut rubs against to create a slightly smaller "ridge" around the outer circumference of the hole. Now the lock pin will go through the hole in one direction but not the other direction. A slight filing of that ridge with a round file should restore the correct diameter of the lock pin hole and allow the pin to insert in either direction. For all axles other than early 1928, the pin inserts from the front of the axle with the locknut on the back of the axle.
Re: Lock pins too large for axle? Quote:
Re: Lock pins too large for axle? Thanks, I’ll try a round file and see how that goes. Makes sense that maybe just the ends are off because of the tightening of the nut
Re: Lock pins too large for axle? I have a coupe with a lot of "interesting" things done to it. This was the second time I had seen the nuts on the front. But when I looked behind the axle more nuts! So it has the long hex nuts on both sides. Anyone seen that before. Kingpins are tight so I left it alone.
Maybe you had an early locking pin with a later nut on the other side.
Re: Lock pins too large for axle? I have a dropped axle in my A V8. The holes were too small,probably due to the dropping. A a quick pass with a reamer fixed it. It should be a snug fit.
John |
Re: Lock pins too large for axle? Well, I took a file to the bores this morning…that did the trick. Front end all put back together. Thanks for the tips
Re: Lock pins too large for axle? Yay! Way to go.
Re: Lock pins too large for axle? FWIW, I ream mine with a 9/16” reamer (0.5625”), from front to back, when I rebuild a front axle. Typically goes right in the front but sometimes requires a bit of a push to get it out the back.
