The Ford Barn
-   -   Removing trans in a 1934 Ford pickup (https://www.fordbarn.com/forum/showthread.php?t=349368)
bill4704 05-23-2025 09:30 AM
1 Attachment(s)
I am attempting to replace the original 1934 trans in my 1934 truck with a 1934 trans. So, far, I have dropped the axel & torque tube and removed all transmission bolts, removed clutch arm & parking brake. Tried to jack up the engine, but the whole truck moves. There seems to be 2 rods about 1/2 half inch wide, holding the engine in place. Any suggestion as to how to get the trans out? Stuck in placed! Photo attached-if I can. Bill
petehoovie 05-23-2025 10:51 AM
Re: Removing trans in a 1934 Ford pickup
https://www.fordbarn.com/forum/attac...6&d=1748010570
cas3 05-23-2025 11:30 AM
You either have to remove the rear axle, (Move back out of the way) or remove the engine. Which method are you trying to do?
alchemy 05-23-2025 12:58 PM
And you will probably have to remove the chatter rods, for either method.
jimTN 05-23-2025 03:16 PM
you will have to raise the engine rear high enough to slide the trans back, of course after the rods are removed at the frame. You will also have to take the exhaust pipes loose from the headers to let the engine move.
deuce lover 05-24-2025 02:46 AM
Drain trans and remove shift tower also
