The Ford Barn
-   -   Fordor/Town Sedan lock knob question... (https://www.fordbarn.com/forum/showthread.php?t=349298)
Marshall V. Daut 05-20-2025 01:20 PM
For you 1929-early 1931 three-window Fordor and Town Sedan owners: Which way should the door lock knob on the inside door panel point in the unlocked position? I know it points downward, but at the unlocked position, should it point to the 5:00 or 7:00 position? It will fit either way. I have looked through publications trying to find the definitive visual answer, but the position varies, both in photos of original and restored cars.
M.
JayJay 05-20-2025 01:58 PM
Re: Fordor/Town Sedan lock knob question...
M.
M- mine was at about the 7:00 locked when I took it apart, and about the 9:00 when unlocked. Or maybe the other way around. In any event, in one state it was horizontal and in the other state it was angled.
J Franklin 05-20-2025 05:15 PM
Make sure the door is unlocked and then install the lever in the down position.
Marshall V. Daut 05-20-2025 06:21 PM
Thanks, Guys. Admittedly a simple question, but why not install this part correctly the first time? It's one of those things that if you orient it correctly, no one says anything. But Heaven forbid you install it incorrectly and everyone who ever saw a Model A drive by 30 years ago will gleefully point out your error. :) In my search through interior photos in books and on-line I saw this poor little knob variously pointing in four directions because the locking mechanism shaft and the knob's receptacle are both square, unkeyed. So, four orientations are possible. I wanted to know the right one. Thanks again.
M.
J Franklin 05-21-2025 12:10 AM
My car had a round shaft with a cross-pin. Only could go on 2 ways.
