The Ford Barn
-   -   1940 Fuel Pump: (https://www.fordbarn.com/forum/showthread.php?t=348913)
40ford 05-05-2025 07:30 AM
1940 Fuel Pump:
Does anyone know if Airtex still makes a fuel pump for a stock 1940 Ford?NAPA used to have them but I can not find a part number now and nothing shows to order for me? Thanks,Russ
petehoovie 05-05-2025 11:49 AM
Re: 1940 Fuel Pump:
AIRTEX FUEL PUMP # 571 - 1940 41 42- 46 47 FORD
Many on eBay > https://www.ebay.com/p/227869341
https://i.ebayimg.com/images/g/knsAA...ln9/s-l500.jpg
And here > https://www.earlyfordstore.com/colle...ass-bowl-u-s-a
https://www.earlyfordstore.com/cdn/s...g?v=1598580831
Check here as well >
https://duckduckgo.com/?t=ffab&q=AIR...g&iax=shopping
barnfind08 05-05-2025 07:18 PM
Re: 1940 Fuel Pump:
I have fuel pump for 40 ford in both driver and correct concourse.
mcgarrett 05-05-2025 09:42 PM
Re: 1940 Fuel Pump:
The pumps pictured above are not "correct" for the '40 Ford if you're working on a concours restoration, but will work just fine otherwise. '40 correct factory installed pumps did not have the glass bowl attached.
