The Ford Barn
-   -   Weiand heads (https://www.fordbarn.com/forum/showthread.php?t=348862)
ken-r-mer 05-02-2025 09:32 PM
Weiand heads
Anybody know where to look for the stamped compression numbers on the Weiand 8BA flatheads?
Kurt in NJ 05-03-2025 05:47 PM
Re: Weiand heads
The Weiand head I have is stamped 2 places,on the gasket surface and near the water outlet.
stamped on the gasket surfaces lets you know if it was cut changing the compression ratio.
It’s not a 8ba head though.
ken-r-mer 05-04-2025 12:49 PM
Re: Weiand heads
The 8BA ones I'm looking at have no visible stamp near nor around the water outlets. No visible marking on the gasket side either. For a 70 yr old set of heads, the chamber side surface looks better than average, so maybe it's been resurfaced eliminating the stamping. Looking for a low compression set of heads for a blower setup or....will have to resort to a thicker head gasket to lower the compression closer to 7.0. Per Roadrunner's charts Weiand had the highest cfm air flow numbers unless you get into exotics like Baron's ($2,600.00+, 6.1 C.R.). The price may be due to the 2nd name on the head (Tattersfield). $1,300 per name.
lonewolf 05-08-2025 01:30 PM
Re: Weiand heads
The large chamber edelbrocks flow pretty good from what I remember and they ate like 7.4 c
