The Ford Barn
-   -   Wiring diagram for a 1932 model B with 12 volt battery (https://www.fordbarn.com/forum/showthread.php?t=348570)
oldford 04-20-2025 10:29 PM
I'm over my head on this one. If they had left it alone with the 6 volt I think I would be OK. One problem is they installed a voltage regulator, Why. I thought all that was needed was a simple cut out. I really need a wiring schematic. The
generator has 2 wires on the top so not sure if it is a generator or?
tubman 04-21-2025 09:21 AM
Re: Wiring diagram for a 1932 model B with 12 volt battery
Doesn't your own second sentence tell you what you really want to do? I'd say you have pretty good instincts.
