The Ford Barn
-   -   pick-up beds & steel (https://www.fordbarn.com/forum/showthread.php?t=348556)
s.e.charles 04-20-2025 01:11 PM
search turned up lots of wood related threads, and the Mack Hils site shows a '31 steel bed option, but i wonder if anyone here has one.
Q: are the dividers between the wood planks still used over a strip steel body, or is what i'm seeing a stamped panel and the bolt heads are holding it to the cross sub-structure?
truck will see no bovine nor other hooved beasts (scale model tow truck w/ custom utility body)
thanks
jimTN 04-20-2025 02:27 PM
Re: pick-up beds & steel
Steel bed floor does not have the dividers and at least thru 34 all PU beds had steel floors.
Kube 04-20-2025 02:34 PM
2 Attachment(s)
At least through '41.
Pictures are of a properly restored '40. Well, not exactly "properly" but rather, over restored.
Karl Wescott 04-20-2025 02:36 PM
Steel floors were used 1931-1950. I assume what the OP stated as a "divider" is what is more commonly called a "rub strip". If so the "rub strips" are stamped into the full floor on the original style. In any case the wood planks are separated by the screws holding the floor or rub strips (and separated about 1/4" to allow air flow which helps prevent rotting).
Krylon32 04-20-2025 04:14 PM
Was a good Idea. My daily driver deuce pickup has the original steel over wood floor and it's solid as new. 93 years.
s.e.charles 04-20-2025 08:23 PM
thanks for the replies & information; very helpful.
s.e.charles 04-20-2025 08:25 PM
but of course i have another question . . . . what is the round access hole for?
replacing gas tank sending unit/ pump?
i trying; honest!
nelsb01 04-20-2025 08:28 PM
Yes --the access is for getting to the gas tank sending unit.
s.e.charles 04-21-2025 02:08 AM
thanks
pistonbroke 04-21-2025 07:19 AM
Yes .Providing you have the corect tank or replacment. I bought a new tank and the sending unit is nowhere near the access port. Tim
s.e.charles 04-21-2025 11:14 AM
i'm a scale model builder and am here just to garner information (& probably annoy) from the guys who actually know stuff. the internet is fraught with "experts" who seem to be 180 degrees off kilter.
i watched a Hemmings video this morning and was really aghast at the unknowledge the host displayed.
s.e.charles 04-21-2025 11:15 AM
but i do take your point of aligning access with that which it is accessing!
