The Ford Barn
-   -   model a cutat polarity sensitiv (https://www.fordbarn.com/forum/showthread.php?t=348472)
Piet 04-17-2025 05:14 AM
3 Attachment(s)
just a double check. The cutout below is not polarity sensitive right? my ford is neg ground.
The cutout with diode is polarity sensitive, I know that. But the mechanical one I started to doubt now. But I don't think so.
fourfords 04-17-2025 05:32 AM
Re: model a cutat polarity sensitiv
This looks like a reproduction cutout. In the photo on the left, The contact on the left goes to the battery. The contact on the right in the same photo goes to the generator.
nkaminar 04-17-2025 06:02 AM
There are two coils: one with small wire and many turns and one with larger wire and fewer turns. The one with small wire is voltage sensitive and closes the contacts once the generator voltage is high enough. The one with fewer turns has the full current running through it once the contacts close and keeps the contacts closed. Neither coil is polarity sensitive.
Piet 04-22-2025 09:43 AM
thanks. There are cut outs that are polarity sensitive right?
J Franklin 04-22-2025 12:04 PM
Ones that use a diode. You can use one for a Model T on -ground.
