Looking for this DIFFICULT to locate part - do you have it? 1 Attachment(s)
1955 Ford Fairlane Club Sedan - need the "L" shaped stud (upside down L anyway) that allows the vent window to pivot. These things are known to rot out. Every last vent window assembly in my stash - all were rotted away to just about nothing.
Passenger side or Driver side, either will fit. See the diagram. Let me know if you have one or where I could purchase one off the shelf. Thanks fellas |
Re: Looking for this DIFFICULT to locate part - do you have it? 1 Attachment(s)
Below is a blow-up of your ILL.
Hopefully it will show large enough to view properly. The part you are describing, is there a BASIC PN with an arrow pointing to it? Your car is a 1955 FAIRLANE TUDOR CLUB SEDAN (70C)? |
Re: Looking for this DIFFICULT to locate part - do you have it? I looked too; can't find that it was serviced separately but only as part of the frame. Not sure of any aftermarket sources for it.
Carpenter has a few listed but for pickups or Broncos. Not sure it they would work or could be modified. Here's one: https://www.dennis-carpenter.com/tru...-pivot-assy-lh |
Re: Looking for this DIFFICULT to locate part - do you have it? Went and looked at my stash and every frame I have does not have that part on it. I guess I cannibalized them to make up the two good ones.
Re: Looking for this DIFFICULT to locate part - do you have it? I am assuming you are looking for the vertical pin that the window rides on. There are few swap meets coming up next month and I can look for you. It may mean getting the whole window if you are good with that. When they get close I can PM you my number so if I find one I can call you.
Mike |
Re: Looking for this DIFFICULT to locate part - do you have it? My avatar had the same part issue. I was able to get one from Shoebox Central-405 259 9222. From the ilustration it appears to be identical. Good luck!
Re: Looking for this DIFFICULT to locate part - do you have it? WOW!
Ask and ye shall receive... you guys are on this, much appreciated. My passenger side vent window is "just a floppin' in the wind" so I need to replace this broken stud/bracket to make Mama happy. Yes, a 70C - 1955 Fairlane Tudor Club Sedan. There is no arrow pointing as far as I can see. I will have to check my other manual to see if I can locate an actual part number. I will contact Shoebox |
Re: Looking for this DIFFICULT to locate part - do you have it? At one time Restoration Specialties (PA) had some of these. Try them
Re: Looking for this DIFFICULT to locate part - do you have it? Is that a part that is likely to be re-engineered from year-to-year?
Re: Looking for this DIFFICULT to locate part - do you have it? Hotrod..............Mine was actually for the rear quarter window but I think they are the same L piece. Careful with glass as I broke mine putting the glass back into the frame! AAArgh!!
Re: Looking for this DIFFICULT to locate part - do you have it? If it is the wing glass frame pivot pin you are after, it was offered only as an assembly (frame incl glass) from FOMOCO -
B5A 7021406-A (RH) B5A 7021407-A (LH) Be careful here if searching EvilBay as there is one offered but the seller has the PN listed incorrectly. His has a BASIC PN (shown) 7621407 (LS) which is for a HDTP or CONV. We have your back REVEREND, and as for myself, the lightening strikes are getting closer ... :( |
Re: Looking for this DIFFICULT to locate part - do you have it? 2 Attachment(s)
found this in my junk pile. You can have it for shipping and whatever you feel.
Re: Looking for this DIFFICULT to locate part - do you have it? ... damn ... |
Re: Looking for this DIFFICULT to locate part - do you have it? Quote:
Re: Looking for this DIFFICULT to locate part - do you have it? I have vent Windows from 56 Mercury, look like the same. Let me know if still need
Re: Looking for this DIFFICULT to locate part - do you have it? I mailed 56sedandelivery a check today - should get there soon. Much appreciated!
And thank you guys for all the quick responses! |
