The Ford Barn
-   -   Large hex nut (https://www.fordbarn.com/forum/showthread.php?t=347873)
Peyton 03-29-2025 09:40 AM
Large hex nut
Found a large hex (gland) nut and wonder if it is used somewhere on the Model A Ford or T.
Course thread 1 3/16 id, 1 3/4 od. Recessed slightly on one side. Can’t locate it in Snyder catalog. Looks very old. Any ideas?
wrndln 03-29-2025 10:12 AM
Re: Large hex nut
A picture would help. Could it be for the inside sediment bowl nut?
Gary WA 03-29-2025 10:12 AM
Re: Large hex nut
Picture would be helpful?
Bob C 03-29-2025 11:02 AM
Re: Large hex nut
1 Attachment(s)
Something like this? A-4634
Marshall V. Daut 03-29-2025 11:05 AM
Re: Large hex nut
Maybe the nut used on the sediment bowl that secures it to the inside of the firewall?
Marshall
Joe K 03-29-2025 12:01 PM
Re: Large hex nut
Castle nut used to hold the clutch-pac to the transmission input shaft on the early Multi-plate clutch?
Joe K
Marshall V. Daut 03-29-2025 01:39 PM
Re: Large hex nut
The original (not the flimsy serrated repo) sediment bowl/bulb nut does have a recess on one side to go over the rounded end of the threaded "nipple" extending through the firewall to secure it better. A photo with the nut lying next to an identifiable Model A part would provide scale to judge its relative size. But I'm pretty sure this is a sediment bulb nut, given the unique recess on one side only. Why else would that recess be there on such a large nut?
Marshall
Bob C 03-29-2025 01:56 PM
Re: Large hex nut
Marshall
That nut is 1 1/4" OD.
Peyton 03-29-2025 04:34 PM
Re: Large hex nut
Would post a picture but I can’t find a way to attach a photo that I did upload in the album section. Doesn’t seem user friendly.
I looked at the old style sediment bowl hex nut inside the car and it’s way too small. All others shown in the Snyder Catalog are much smaller. Sorry that I led y’all on a wild goose chase.
Thanks to all for your posts!
Bob C 03-29-2025 04:53 PM
Re: Large hex nut
1 Attachment(s)
Here's the picture.
Bob C 03-29-2025 05:58 PM
Re: Large hex nut
The closest nut I see in the parts book is A-21951 1 1/8-16 9/16" thick 1 11/16'' OD Dual high power take off gear nut.
Peyton 03-29-2025 09:47 PM
Re: Large hex nut
Bob C, thanks for getting the picture up for me. I found the nut when going thru a tray of nuts and washers. Thought it might be Model A or T related. By close measure it appears to be 1 1/4 inch id. So it could be pipe related — also a course thread.
But it did look kind of Model A era to me.
Tom Endy 03-30-2025 01:05 AM
Re: Large hex nut
Originally Posted by Bob C (Post 2379863)
Here's the picture.
Looks to me to be the nut used on the pinon gear sleave in the differential. There are two used to adjust the bearing pre-load and to lock together.
Tom Endy
katy 03-30-2025 11:02 AM
Re: Large hex nut
Quote: "Would post a picture but I can’t find a way to attach a photo"
Go to the bottom of the thread,
Click on "Go advanced"
Near the top, click on the paper clip icon (attachments)
A little screen (Manage attachments) will appear,
Click on: "choose file"
Simples
Bob C 03-30-2025 11:13 AM
Re: Large hex nut
1 Attachment(s)
Yes it could be a pipe lock nut. https://www.mcmaster.com/4638K616/
Peyton 03-30-2025 01:57 PM
Re: Large hex nut
Bob C, thanks again. That looks like it and the od is exactly 1 3/4 inches!
stevests 03-30-2025 03:19 PM
Re: Large hex nut
Looks like a Model T Holley G bowl nut.
