Cutting the thrust bearing Hey
Does anyone know the distance from the center bolt to the milled face on the K.R.Wilston jig to cut the rear main thrust bearing on the model A? So the crankc ends up in the right place. I also need the dimensions for the V8 jig. Thanks Leo |
Re: Cutting the thrust bearing Try the early V8 forum.
https://www.fordbarn.com/forum/forumdisplay.php?f=4 |
