Roof top tack strip How well does the roof top tack strip fit on a 32. I would think the corners would be the problem area. Is there an alternative that someone has used.
Re: Roof top tack strip Use #2 or #3 wood screws with Robertson heads in the four corners.
Re: Roof top tack strip That's good for the screws but I need infor on the tack strip.
Re: Roof top tack strip Quote:
Re: Roof top tack strip The UPAC metal kit fits well. My son used it to make workon his for door was fine. Used the kit on my coupe worked fine
Re: Roof top tack strip Who or what is UPAC? I can't find it on the web.
Re: Roof top tack strip I used a UP kit on my deuce 5 window, worked good.
Re: Roof top tack strip |
https://classic.upauto.com/about-us-2. |
Re: Roof top tack strip I'm talking about the pre bent ones. The UP ones are straight. And it would be impossible for me to bend one to fit the curve corners without it deforming. It's for a 32 coupe.
Re: Roof top tack strip They sold bent parts for front and rear. Straight pieces for the side. You need four pieces from them front rear one long piece to make the sides
