The Ford Barn
-   -   '40 Ford Dome Light order (https://www.fordbarn.com/forum/showthread.php?t=347649)
WarbirdPhotog 03-22-2025 04:30 PM
Hey all, question on the dome lights for the 1940 Ford. I guess I didn't document my disassembly as well as I should have with these lights, but they were missing the gaskets. So there's five parts, the metal housing with the bulb, the plastic light diffuser that's white, a paper gasket, a metal retainer, and the metal bezel. What order do these go in?
https://uploads.tapatalk-cdn.com/202...9841857328.jpg
Kube 03-22-2025 05:50 PM
Re: '40 Ford Dome Light order
Lens goes against bezel. Then the gasket against the lens. Then the retainer against the gasket.
WarbirdPhotog 03-22-2025 10:16 PM
Thanks Mike! And when illuminated, because of how the bulb is angled slightly outward... Does it normally only appear half lit?
https://uploads.tapatalk-cdn.com/202...8e3e512ccd.jpg
Kube 03-23-2025 08:21 AM
I'd never noticed one "half lit". Doesn't mean it didn't occur just that I'd never noticed that before.
Karl Wescott 03-23-2025 01:02 PM
As an aside... the housing is also used for the parklight on 1940-41 trucks and 1940-47 cabovers.
joel 03-23-2025 02:26 PM
Looking at the assembly, I don't think it has any choice. The socket+ bulb base occupies more space than the bulb. You might get more reflection if you used the fake chrome paint on the inside of he base. Guys used to do that with taillight housings.
