The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   Edelbrock 1403 (https://www.fordbarn.com/forum/showthread.php?t=347385)
OldMercs 03-14-2025 01:29 PM
Edelbrock 1403
I think I've narrowed my carb choice to an Edelbrock 1403 Performer 500 cfm w/electric choke but as always I'm interested in thoughts/advice from those who know more than me.
This is going on my '54 Mercury 292. It's a cruiser, not performance necessarily but I want to be able to keep up.
Also, will I need a spacer and if so how much?
miker98038 03-14-2025 02:14 PM
Re: Edelbrock 1403
If I’m right, this is going on a B manifold, so it’s got the modern square bore bolt pattern. So a spacer wouldn’t be needed for the installation, but would be for heat isolation.
I like the Eddy Carter clones, and have used 1406’s and 1405’s. Both manual and electric chokes. Easy to tune, just takes a bit of time to get your head around the tuning section of the manual. Easier jet changes than a Holley IMO.
But there’s been a lot of talk that the Summit series, based on the Autolite 4100 design runs really nice on the street. It uses annular venturies for better low speed atomization.
You can find some comments on that over at yblocksforever, and also on the Mustang sites for guys replacing autolites that were oem.
Just a thought. One thing Ted Eaton’s found on his dyno testing is the vacuum or flow operated do a good job of not over carbing an engine. But a 500 or so will be fine until you get into more work on the airflow side.
Just one as an example.
https://www.summitracing.com/parts/s...00vs?rrec=true
paul2748 03-14-2025 07:36 PM
Re: Edelbrock 1403
I assume that you have a 57 or later distributor? If not, you will need it with either the Edelbrock or the Summit.
OldMercs 03-14-2025 08:11 PM
Re: Edelbrock 1403
I'm looking for one now.
KULTULZ 03-14-2025 10:49 PM
Re: Edelbrock 1403
Do you know what year 292 is in the MERC?
Is it a 2V or 4V?
OldMercs 03-15-2025 07:36 AM
Re: Edelbrock 1403
Is it a 2V or 4V?
I believe it's a 61. The block id is C1AE. I got it as a 2V. I found a B intake cheap so I'm upgrading to a 4V. Fun project with my grandson.
KULTULZ 03-15-2025 08:22 AM
Re: Edelbrock 1403
I think I asked all of this in an earlier thread and CRS is not kind.
You SHOULD have the DUAL DIAPHRAGM DIST.
You will have the F100 2V CARB on it. Are you having carb performance problems are do you just want more go?
Do you know if the later F/M trans came with the swap?
scicala 03-15-2025 10:30 AM
Re: Edelbrock 1403
If it's a '61 292 you should be fine with the distributor it came with provided it has centrifugal advance and vacuum advance.
Sal
Gene F 03-15-2025 12:54 PM
Re: Edelbrock 1403
"You SHOULD have the DUAL DIAPHRAGM DIST."
Just change the vac chamber on the dist? Why? How does the dual work (short sequence of operation)?
OldMercs 03-15-2025 01:34 PM
Re: Edelbrock 1403
5 Attachment(s)
Sal
Here's a few pictures of my distributor and any identification I found on it. I need help determining what year it is and if it will work with a Edelbrock 1403. Thanks
KULTULZ 03-15-2025 02:22 PM
Re: Edelbrock 1403
Bad news. The DIST is LOAD-O-MATIC.
Can you show a photo of the CARB and any intake manifold ID NOS you see?
Something ain't right here.
KULTULZ 03-15-2025 02:31 PM
Re: Edelbrock 1403
The LOAD-O-MATIC DIST has only a modified vacuum signal advance.
The DUAL ADVANCE DIST has both ported vacuum signal MANIFOLD VACUUM ADVANCE along with a mechanical advance set-up using advancing centrifugal weights.
CLICK HERE - http://m571.com/yblock/loadomatic.htm
Gene F 03-15-2025 04:02 PM
Re: Edelbrock 1403
I have a 57. So I think I have my answer. Thanks
paul2748 03-15-2025 04:03 PM
Re: Edelbrock 1403
The dual diaphram only came on 56 cars as far as I know. Unless it came sometime later (60's).
OldMercs 03-15-2025 04:15 PM
Re: Edelbrock 1403
3 Attachment(s)
Here's the carb & manifold that was on the car with the Load-O-Matic. I'm replacing them with a "B" manifold & Edelbrock carb.
OldMercs 03-15-2025 04:17 PM
Re: Edelbrock 1403
Great read. I enjoy knowing more about these technologies. Thanks
OldMercs 03-15-2025 04:21 PM
Re: Edelbrock 1403
Hot Rod Reverend 03-15-2025 10:14 PM
Re: Edelbrock 1403
late to the party but check out this video, it will help explain the situation with the distributors in the 50's...
https://youtu.be/od5V6cWjEAM?feature=shared
KULTULZ 03-15-2025 10:58 PM
Re: Edelbrock 1403
... hmmph ...
I bet this engine will not even get out of it's way.
The intake is correct for a 1960-1962 car engine. It has a 1974 F-2150 2V CARB on it.
If it was an update engine swap (not wanting to rebuild the 256), why would they use a 1956 LOM DIST?
Is the a vacuum signal line running from the carb to the DIST ADVANCE CANISTER?
Did they paint the engine green (original MERC 256CI color)?
KULTULZ 03-15-2025 11:09 PM
Re: Edelbrock 1403
Very well presented Reverend.
