Want 15" reverse F100 Wheel 5 on 5-1/2 Need reversed center wheel for 1960`s f100 wheel as the stock wheel is rubbing my drag link, only need one, thanks
Re: Want 15" reverse F100 Wheel 5 on 5-1/2 I’m not sure changing the offset on just one front wheel is going to be your friend. Maybe both. See if there’s a wheel repair shop around that can do it to your wheels. I know Wheelsmith in CA used to do that work. But if you’re cross country, that won’t help much.
Re: Want 15" reverse F100 Wheel 5 on 5-1/2 Thank You I`ll chk Wheelsmith
Re: Want 15" reverse F100 Wheel 5 on 5-1/2 |
Re: Want 15" reverse F100 Wheel 5 on 5-1/2 Are you sure you don't have one mismatched wheel?
If you switch wheels, does the new wheel rub? |
Re: Want 15" reverse F100 Wheel 5 on 5-1/2 Yes
Re: Want 15" reverse F100 Wheel 5 on 5-1/2 Quote:
What exact year and 2WD or 4WD? |
