No start Chasing a no start 1937 Ford 6 volt model 60 . I have very low spark so I relaced the coil -no good ,- tested the condenser with ohm meter -good , Pulled the distributor off to check points and half the cam keyway on distributor is missing . It appears to have been like that for a while. Distributor is helmet style with external coil. Car has been sitting for 6 months. Can I go to the crab style distributor ?
Re: No start Quote:
It's been a long time since I messed with a V8-60 (if that's what you have), but I think rounding up the parts to install a crab may be difficult if not impossible. |
