The Ford Barn
-   -   Oil return in pan (https://www.fordbarn.com/forum/showthread.php?t=346761)
elwood 02-23-2025 11:31 AM
Oil return in pan
2 Attachment(s)
Hey guys, Im pretty sure this is for the oil return from the canaster to the pan,
Im pretty sure the zert screwed in to it was just to plug it.
But, is this the oil return to the pan from the canaster location ?
Its got a very small little slot on the bottom side, dont seam like much oil would come through it.
Bored&Stroked 02-23-2025 11:32 AM
Re: Oil return in pan
We need a picture!
From what you're describing, it is the oil return line from a "drip-feed" original Fram type setup. There is a little 'slot' on the bottom where the oil comes out.
elwood 02-23-2025 11:40 AM
Yep, little slot in the bottom.
Thanks B&S
Originally Posted by Bored&Stroked (Post 2371595)
We need a picture!
Kube 02-23-2025 12:04 PM
Yep, that's a 1941 pan.
cadillac512 02-23-2025 01:51 PM
It's surprising how much hot oil comes out of a slot like that, even with the proper restrictor in the filter feed line. :eek:
