The Ford Barn
-   -   GAZ pistons and connecting rods (https://www.fordbarn.com/forum/showthread.php?t=346727)
lsr490 02-21-2025 07:50 PM
Just curious if there is any value in these. The little history that I have this short block arrived in California in the early seventies. The block was cast July 23rd 1962. I believe the motor had around 5k miles on when I decided to rebuild it with inserts and a high compression head.
lsr490 02-21-2025 07:58 PM
Re: GAZ pistons and connecting rods
Picshttps://uploads.tapatalk-cdn.com/202...e9be4cae28.jpghttps://uploads.tapatalk-cdn.com/202...dad4b47ef4.jpghttps://uploads.tapatalk-cdn.com/202...045069ef11.jpghttps://uploads.tapatalk-cdn.com/202...b76f0da29f.jpghttps://uploads.tapatalk-cdn.com/202...dd7b6ea4d8.jpghttps://uploads.tapatalk-cdn.com/202...70629f19ab.jpghttps://uploads.tapatalk-cdn.com/202...3a2e9a1c4d.jpghttps://uploads.tapatalk-cdn.com/202...54e8910b78.jpghttps://uploads.tapatalk-cdn.com/202...db56e0ae07.jpg
Sent from my SM-S906U using Tapatalk
lsr490 02-21-2025 08:01 PM
Motor picshttps://uploads.tapatalk-cdn.com/202...b41f12a4e1.jpghttps://uploads.tapatalk-cdn.com/202...19acefb684.jpghttps://uploads.tapatalk-cdn.com/202...d85e94cf3c.jpg
blacknblue 02-24-2025 04:27 PM
Pretty cool. I saw a GAZ-A in Russia when I was there a few years back in a museum.
rotorwrench 02-24-2025 08:47 PM
The chances of used rods fitting a different crankshaft would be a bit on the slim side. It would likely require them to be repoured with new babbitt for refitting to a different crank journal size. They have core value but that's about it. The same problem would exist with the used pistons.
