fuel bowl fill of oil ford 8ba eng stoped runing fuel bowl fill with oil .i have seen maney fuel pumps that went bad put gas in crank case. i have never seen a fuel bowl full of oil & the fuel pump is mounted high on eng
Re: fuel bowl fill of oil It sounds like the crank case vent is plugged and the fuel pump is pulling a vacuum on the engine
Vic |
Re: fuel bowl fill of oil Maybe diesel in the tank ?
Re: fuel bowl fill of oil the eng has a road tube also a oil filler pipe whitch is clear there is no blow by it is runing on a 1 gallon can not hooked up to fuel tank eng sounds terable sounds like glass brakeing no miss. just wondering if any one has seen this i will dissamble eng to see what i find
Re: fuel bowl fill of oil That is a new one . Id suggest a compression check before tear down. Just to determine if it’s specific to some cylinders. Good luck and please keep posting results. Thanks
Re: fuel bowl fill of oil Quote:
Re: fuel bowl fill of oil this is pure thick oil
