The Ford Barn
-   -   9 1/2" diaphragm pressure plate (https://www.fordbarn.com/forum/showthread.php?t=345676)
Bullerman 01-18-2025 08:09 PM
Does anyone make a 9 1/2" diaphragm style pressure plate to replace the stock three finger that will fit a stock flywheel for the 239 cu in. I have a 50 model.
paul2748 01-18-2025 08:13 PM
Re: 9 1/2" diaphragm pressure plate
Try Centerforce
Ronnieroadster 01-19-2025 03:59 PM
You might find something smaller that the standard 10 inch size possibly from a foreign car application. But I'm wondering if it would be worth the searching, experimenting and expense compared to just using a flathead flywheel with the 10 inch bolt pattern.
Ronnieroadster
