The Ford Barn
-   -   53 Mercury front disc brake conversion. (https://www.fordbarn.com/forum/showthread.php?t=345611)
dean333 01-16-2025 06:10 AM
I have the kit from POL. I just found out my Monterey has dropped spindles. Has anyone had issue with the brake hoses being too short to route behind the king pin due to the dropped spindle support? I watched a YouTube video of the kit being installed on a 53 Ford and he had to grind the area of the caliper where the brake hose connects to allow the hose to swing forward and get more room to route behind the king pin. Its at 22:08 of the video.
The shop manual doesn’t describe any subtle differences, if any, between 53 Ford and Mercury brake systems.
dean333 01-16-2025 06:13 AM
Re: 53 Mercury front disc brake conversion.
Here’s the video. The installer also had a few other issues with supplied caliper brackets not quite fitting right, had to do some grinding for clearance at the dropped spindle support. The Tech Support at POL had no idea.
https://youtu.be/pBdAN2vhE6M
dean333 01-19-2025 10:10 AM
No one??
glennpm 01-19-2025 10:22 AM
Originally Posted by dean333 (Post 2363313)
No one??
You'll probably have better luck on HAMB
https://www.jalopyjournal.com/forum/...l-hot-rods.57/
dean333 01-19-2025 11:57 AM
Too many pop ups before I even get to login on the Hamb. Forgot my password and there’s no direction to fix the problem.
glennpm 01-19-2025 12:54 PM
Sign on located in top right corner.
https://www.fordbarn.com/forum/attac...4&d=1737309153
