34 3 window body on 35 frame With all this knowledge floating around :)
what does it take to fit a 34 3 window body on a 35 frame? Thanks |
Re: 34 3 window body on 35 frame Magic. the 35 frame is longer and wider and of course the fenders would not work.
Re: 34 3 window body on 35 frame Don't waste your time. It would look like c*ap. There are used '34 frames out there. Do it right the first time.
Re: 34 3 window body on 35 frame Model 40 bodys bolt directly to the frame in all locations, not sitting on pads like the 35-40 frames so there aint no way to fake it
Re: 34 3 window body on 35 frame Welcome aboard!
Re: 34 3 window body on 35 frame If you got a nice 34 body don't F--K it up by taking a shortcut to save some bucks. If you can't afford it now, just file it away until you can do it right.
Re: 34 3 window body on 35 frame I think that about sums it up !
What all the above said ! |
