spring perch I see from my green bible that the 40-3030 perch is listed as fitting passenger cars 32-34,
But. in B/Drakes they only list it as fitting a 32 My question, is ,are they the same. Thanks Lawrie |
Re: spring perch Well, I used the search function, looks like they are the same except for the embossed B in the part number.
Is this right. Lawrie |
Re: spring perch Probably, to my way of thinking, 32-34 front ends are identical, apart from the 'famed' 32 'heavy axle' and 32 wishbone.
Re: spring perch The '33-'34 passenger car/commercial vehicle spring perches are not the same as their '32 counterpart. On the the '33-34 version, the spring shackle bore is about 1/8" higher on the perch pin. If mixed with a '32 pin, the front end will end up slightly lop sided.
Re: spring perch Comparing one of each side by side the difference appears to be very minor. The 32 can be used on the 33-34 in pairs.
Re: spring perch Thank you for the info.
Lawrie |
Re: spring perch The later 40* perch would have been a service replacement for the B* perch. You'll want to use it in pairs as noted by David, though.
