37 flathead spark plug wires needed Ok guys 37 motor stock
Did pertronix upgrade with there coil also What about spark plug wires What are you guys using Has the 42 crab style distributor Thanks car is 12 volt converted |
Re: 37 flathead spark plug wires needed I’ve read a number of times that you need to use specific wires for a pertronix ignition…..I’d contact them for advice……….Mark
Re: 37 flathead spark plug wires needed Yep. It seems like that if you want to use one of their units, you have to do it exactly the right way to have a reasonable chance of success.
Re: 37 flathead spark plug wires needed I sent them an email
Re: 37 flathead spark plug wires needed Ordered pertronix 708190
Re: 37 flathead spark plug wires needed 3 Attachment(s)
All installed along with the electronic point conversion super easy
Re: 37 flathead spark plug wires needed Never seen the wires routed quite like that. It'll be interesting to see how it works out.
Re: 37 flathead spark plug wires needed 2 Attachment(s)
I need to make something up to hold them Here is my 68 firebird and my son's 51 chevy I did |
Re: 37 flathead spark plug wires needed I am not a fan of the red and black wires routed through the side of the housing without any grommet or seal.
Re: 37 flathead spark plug wires needed Brillman has an excellent selection and I have their wires on my avatar for years. They wre fisted fir long life, work with a Pertronix system, and I have no fenders or hood sides and no problems in heavy rainstorms.
Re: 37 flathead spark plug wires needed Quote:
They have (or at least used to have) a nice printed catalog. |
Re: 37 flathead spark plug wires needed I used Stromberg's wire set. They seemed to excellent quality and were easy to work with. Will work with Pertronix.
