The Ford Barn
-   -   37 flathead spark plug type...... (https://www.fordbarn.com/forum/showthread.php?t=345205)
Ohc Joe 01-01-2025 02:16 PM
3 Attachment(s)
Okay guys what kind of spark plugs do you guys recommend on these motors I got the distributor figured out and the pertronix unit is on its way next will be spark plugs also I think this fuel pump is bad I need to figure something out there too anybody run electronic fuel pump straight to this mechanical unit with some type of regulator in between to help it out
Herb Concord Ca 01-01-2025 03:41 PM
Re: 37 flathead spark plug type......
Might have better luck posting on the Early Ford V8 forum.
katy 01-01-2025 07:16 PM
Champion H10 IIRC
Ohc Joe 01-01-2025 08:25 PM
Ok i will re list in early forum
CT Jack 01-01-2025 10:05 PM
Fuel pump fix. Remove the the pump drive arm, reinstall the pump, install a 6v or 12v pump fuel pump, and connect to the stock fuel pump. It will work all the time and nobody will know except you.
Y-Blockhead 01-02-2025 12:13 AM
I am not familiar with Flathead fuel pumps but have seen on other engines where the electric pump was plumbed thru the mechanical pump and the diaphragm sprung a leak, it fills the pan with gasoline. Something to think about.
Ohc Joe 01-03-2025 10:18 AM
Yeah good idea
What's the psi on these flathead motors I'll have to get a fuel pressure regulator this way the stock pump doesn't have to much pressure
