The Ford Barn
-   -   Looking for body number plate (https://www.fordbarn.com/forum/showthread.php?t=345037)
99sh 12-26-2024 10:37 PM
I'm looking to get a Briggs body number plate with my SN stamped. Does anyone offer well made repos?
I saw some older posts to contact [email protected] however have not received a response in weeks.
JayJay 12-26-2024 11:54 PM
Re: Looking for body number plate
Some of the Model A parts suppliers offer blank repos, you'd need to stamp your own numbers.
Joop 12-27-2024 06:53 AM
Gwyn passed away and Larry sold the stamping tools.
Which model do you need it for.
Bob Bidonde 12-27-2024 09:32 AM
See Bratton's Part Number 26720.
99sh 12-27-2024 11:33 AM
I need it for a 30'
Tracking the usual resellers have these; however heard they are of low quality.
ModelA29 12-27-2024 02:21 PM
The original tags used an acid etch process. All the new ones are just silk screened onto a flat plate.
You can DIY too. This is using brass but you can do aluminum or steel too.
https://www.youtube.com/watch?v=7Op6H0C18tM
vinyl mask https://www.youtube.com/watch?v=_zavCqw2JDU
Bigsnapper43 12-27-2024 08:11 PM
I take the blank tags to a trophy shop who sets up one of his machines and makes it look like Henry put the numbers. I also have had him date the tags for the horns I restore, Sparton tags.
99sh 12-28-2024 11:50 AM
What my real problem is, is my original tag is painted over. If I pop the tag off and dip it in paint stripper would that remove the original markings? I'm not super familiar with acid etching.
Model A Canuck 12-28-2024 12:11 PM
Try here
www.cwmoss.com
JayJay 12-28-2024 12:13 PM
Yes it will remove the original paint. Made that mistake with Brakleen.
Joop 12-29-2024 06:29 AM
Can you post picture of the original tag.
99sh 12-29-2024 02:38 PM
2 Attachment(s)
Here are some pics I have on my phone. Can take close-up ones later next week.
Joop 01-02-2025 11:36 AM
I would remove it from the firewall and soak it in hot water and maybe you can peel the paint off. To remove the rivets go inside the firewall and hit them with a hammer.
Joe K 01-02-2025 01:18 PM
Likely the plates have not been "etched" or otherwise "micro-prepared" (i.e. blasted) prior to painting. Thus there is likely not much adhesion holding the paint to the plates.
Temperature change is your friend. The expansion of acrylic (plastic) is like 7x the underlying metal surface. This is why paint frequently "bubbles" or "cracks" applied over a metal substrate without etching/surface preparation.
And a solvent solution (i.e. soap in water) will help break the adhesion.
Joe K
jw hash 01-02-2025 11:18 PM
remove the tag and soak it in some Lacquer thinner. it should peel the Paint off. My Victoria body had been painted four times. and I stripped the tag. over 40 years ago.
I need to add DO NOT use a wire brush it will scratch the tag
99sh 01-06-2025 06:51 AM
1 Attachment(s)
Well, I'm getting there but not as clean as I would've liked. Was able to remove the paint however the primer which almost feels like body filler is caked on there. Had to use a blade to scrape off the surface even after soaking it in lacquer thinner.
I don't see any black on brass repro tags out there either.
ronn 01-06-2025 07:22 AM
I buy repro tags on ebay- 20 at a time. cost about 20. each
stamp my own and keep then a bit imperfect.
