The Ford Barn
-   -   Keys (https://www.fordbarn.com/forum/showthread.php?t=344673)
john greco 12-08-2024 11:49 AM
Keys
Hi , who makes keys for early fords off numbers on locks ? Thanks John
51504bat 12-08-2024 02:36 PM
Re: Keys
32phil here on the Barn
corvette8n 12-09-2024 08:52 AM
Re: Keys
https://www.fordbarn.com/forum/showt...ghlight=32phil
Check out this thread for info, He made a set for me from the numbers on the passenger side lock.
DavidG 12-09-2024 09:12 AM
Re: Keys
32phil times two.
Kube 12-09-2024 01:05 PM
Re: Keys
Originally Posted by DavidG (Post 2355017)
32phil times two.
Make that THREE :)
deuce lover 12-09-2024 03:42 PM
Re: Keys
And 4 !!
325w 12-09-2024 10:07 PM
Re: Keys
And 5-6
Zeke3 12-10-2024 11:06 AM
Re: Keys
Contact him soon before he heads South for the Winter.
john greco 12-10-2024 11:28 PM
Re: Keys
Got them ordered right in time. Thanks all
WarbirdPhotog 12-13-2024 02:40 AM
Re: Keys
Originally Posted by 325w (Post 2355156)
And 5-6
And 7. Did a great job on my original 1940 Fordor glove box lock!
mark180 12-13-2024 01:41 PM
Re: Keys
Hey, question about keys. I inherited my dad’s 37. The keys are really worn. How can I get “new” keys made? I can have them “duplicated” but they will still be worn. You guys mentioned the code on the lock. Where is it located?
Zeke3 12-13-2024 08:57 PM
Re: Keys
The door lock cylinder from the right front door will have the code for the ignition key. Be sure to use lots of penetrating oil on the set screw that holds the door lock cylinder in, the screw is very easy to damage.
The glove box lock will have the code for the trunk lock stamped on its side.
32phil could probably make you a new key from your worn out one, just by seeing the profile. Check with him to see if he can make one from a picture.
deuce lover 12-14-2024 01:33 AM
Re: Keys
Sent you a PM
34fordy 12-14-2024 05:28 PM
Re: Keys
32phil is a master with his key and lock experience. As little as shipping costs are the preferred way is to send the key cylinder to 32phil. I think he prefers that method and when you get it back it will work BETTER than new!
