The Ford Barn
-   -   1932 Ford Coupe Dimensions (https://www.fordbarn.com/forum/showthread.php?t=344589)
olddragracer 12-05-2024 01:59 PM
I have been unsuccessful finding exterior and interior dimensions for a 1932 Ford Coupe (3 or 5 window). I can find frame dimensions and Model A body dimensions, but no luck for the Deuce body. Does anyone have an idea where I might find these dimensions? Thanks!
deuce lover 12-05-2024 03:18 PM
Re: 1932 Ford Coupe Dimensions
They are printed in The 32 Ford Book by David Rehor.Body and Chassis dimensions,Appendix A-5.
DavidG 12-05-2024 06:19 PM
Sheldon,
I thought of those as well. They are from the Salesman's Manual, but limited to a side view and mostly pertain to the seat and its location within the body. I know of no source for this open-ended question other than taking measurements from actual bodies.
Likely the best bet for olddragracer short of measuring actual bodies would be copies of the SK drawings from the Benson Ford Research Center at the Henry Ford in Dearborn.
Karl Wescott 12-05-2024 07:09 PM
I have a VERY rough 5 window body in our "reference library", and our 3 window molds might be of use if the OP was able to come to our shop to measure.
Note to OP, please indicate your location in your profile.
