The Ford Barn
-   -   Correct Model "A" Bumpers. (https://www.fordbarn.com/forum/showthread.php?t=344257)
Model "A" Fords 11-23-2024 12:58 PM
Bumpers with the correct finish, as original.
I'm thinking of making new bumper bars looking as they were, just off the assembly line. Original bumpers had the mill finish on the back, ends and edges that were pickled and unpolished. It left those surfaces with a dull finish. The faces were smoothly polished with a bright Chrome finish.
I understand they used a different Nickel process than generally used today and would be needed to replicate the bumpers original look.
Any company that does this work?
Bleedblue4life 11-24-2024 03:48 PM
Re: Correct Model "A" Bumpers.
https://customplatingspecialist.com/...-TFFpyeT7k-JFA
Hold on to your wallet, I think I was quoted about 1k per bar. If you're looking for fine point there are alternatives.
Flathead 11-24-2024 04:28 PM
Need to use spring steel like original, that may complicate things.
Gary Karr 11-24-2024 07:59 PM
Christensen Plating in Vernon, CA (LA) used to do the best and most correct plating on Model A bumpers. The last ones I had done by them were about $1000 per bar. I'm not sure that they are even still plating though.
Model A Canuck 11-24-2024 08:36 PM
THE PLATING HOUSE OF CANADA
116 Unit C-1 Viceroy Rd Concord Ontario
1-877-661-3964
www.platinghouse.com
ronn 11-25-2024 05:07 PM
your dollar goes further in Canada, but then theres the shipping...........
Model "A" Fords 12-04-2024 10:23 AM
Thanks' for the responses. I now have more places to investigate. I appreciate all the help!
ronn 12-05-2024 10:26 AM
1000. a bar seems pricey, BUT maybe they could be done in mass up in Canada and brought over. Cores are relatively cheap.
would there be import duty, since they would be "antiques"?
