acceleration This just started happening. When I take the car out the acceleration seems to not come down all the way. I have to tap the gas peddle then it would return to normal. Could this be the return spring?
Re: acceleration Check the accelerator linkage on the firewall and the Carb to find the binding area.
Re: acceleration I agree with Terry about the sccelerator linkage spring on the firewall. I had one get weak and the accelerator would not return properly. It's an easy fix but requires you to take the accelerator linkage loose or completely off to slip on a new spring.
Re: acceleration Also check for a vacuum leak
Re: acceleration thank you everyone. Will check this weekend
Re: acceleration Quote:
If it was mine, and if I had that issue, I would certainly add one drop of motor oil to all 'points' that move, swivel or slide - pedal to carb ~ https://encrypted-tbn0.gstatic.com/i...F7g&usqp=CAE&s |
Re: acceleration That little drop of oil seems to have worked. Thank you
