The Ford Barn
-   -   First V8 (https://www.fordbarn.com/forum/showthread.php?t=344097)
Dave Mellor NJ 11-18-2024 01:16 AM
First V8
1 Attachment(s)
What's he holding?
old31 11-18-2024 03:34 AM
Re: First V8
Maybe a set of points?
mercman from oz 11-18-2024 06:32 AM
Re: First V8
https://www.fordbarn.com/forum/attac...p;d=1731910574
First Ford V8 - What is he holding? Dave Mellor
rfitzpatrick 11-18-2024 06:52 AM
Re: First V8
Two-blade Fan? So when did the 4's happen on original equipment?
marc silva 11-18-2024 08:27 AM
Re: First V8
Looks like maybe a set of distributor centrifugal weights?
gdmn852 11-18-2024 10:45 AM
Re: First V8
Hello, those early V8 s were in a constant state of development, with the owners being the “field testers “. Hard to correctly restore them with changes happening almost weekly it seems. From what I have read Ford was offering new engines available in March 1933 ! for the 1932 models, that owner could buy , also a lot of pistons changed out under warranty.
katy 11-18-2024 10:59 AM
Re: First V8
Is that engine still in the Henry Ford museum? I remember seeing it there in 1956 or 7.
Maybe he's just winding his watch.
Lawrie 11-18-2024 07:26 PM
Re: First V8
its an advance unit for there distributor
Lawrie
midgetracer 11-18-2024 08:18 PM
Re: First V8
When was that type of fan used?
Dave Mellor NJ 11-19-2024 12:53 AM
Re: First V8
I thought if it was points he would have the distributor open, anyway, didn't the V8 have dual points?
Bob Bidonde 11-19-2024 08:00 AM
Re: First V8
Henry is looking at his pocket watch.
katy 11-19-2024 11:21 AM
Re: First V8
Affirmative
mass A man 11-19-2024 11:35 AM
Re: First V8
Looks like the dual-point distributor plate to me.
fourfords 11-19-2024 06:28 PM
Re: First V8
That fan was used in 1932 to clear the coil.
mcgarrett 11-19-2024 07:14 PM
Re: First V8
If you're asking when did the 4 cylinder engines go with a 4 blade fan, I read that the 4 blade was originally used on 33-34 Model BB trucks; maybe '32 also, but not certain. The idea being the big trucks moved at slower speeds with heavy loads so the engineers wanted to move more air. Others here may have more accurate info.
