Which goes first...... A good friend of mine is re-assembling his long delayed Model A project and he asked me a question I cannot answer. But I know where I can get an answer! He is to the point of installing the gas tank and the windshield assembly. Which should he install first or does it matter? :confused: It is a '31 Tudor if that matters.
Thanks for your help. |
Re: Which goes first...... 1 Attachment(s)
Gas Tank then glass would be the way!
Re: Which goes first...... Quote:
Installing the windshield is definitely a two- or three-person job. Gas tank you can get by with two. |
Re: Which goes first...... Thank you. That looked to me to be the reasonable path to take but you folks have the experience.
Re: Which goes first...... Nice lookin' '49.
Re: Which goes first...... Thank you katy. That was my first flathead and I have been a fan of them ever since.
Re: Which goes first...... Back when, worked on them all, from the early ones w/water pumps in the head, up to and including the early '50s ones w/the top mounted distributor.
