The Ford Barn
-   -   Brake Pedal return spring placement (https://www.fordbarn.com/forum/showthread.php?t=343595)
JohninKuranda 11-01-2024 03:09 AM
I have just installed a Float-A-Motor kit on my Model A. Previously I hooked the end of the Brake Pedal Return Spring into the hole in the original engine mount. With the kit, I no longer can do that. I am now a tad perplexed as to what/where I now attach the end of the spring.
Any suggestions?
Thanks
John
johnbuckley 11-01-2024 04:22 AM
Re: Brake Pedal return spring placement
I wrapped a bit of chain around the engine mount and hooked it onto that.
JayJay 11-01-2024 04:56 AM
Any suggestions?
Thanks
John
John - I had the same issue with the FaM. I made a small bracket out of (I think) 1/4” x 3/4” flat stock that bolts onto the engine via the flywheel housing bolt. I then used an eyebolt to attach the spring to this bracket.
Big hammer 11-01-2024 07:30 AM
It’s time to go through your brake system ! The spring you’re taking about isn’t original or needed if your brakes are working properly. The brake rod return springs need your attention as they pull the brake rods off and in turn all of the linkage to the brake pedal
Bob Bidonde 11-01-2024 08:48 AM
1 Attachment(s)
This may help you. I bought the spring at Home Depot.
Will N 11-01-2024 10:05 AM
Yup. No return spring needed if your brake system works right.
mass A man 11-01-2024 12:15 PM
The "helper" spring does do just that. It "helps" with a more positive return of the brake pedal, even when ALL brake parts have been either replaced or restored. I think Ford knew about a weak return system since Ford went to a different brake rod return spring in later part of '31. The Ford update parts didn't end when the Model T was phased out.
johnbuckley 11-01-2024 12:45 PM
I totally agree with you !:):)
Herb Concord Ca 11-01-2024 12:53 PM
I drilled a hole through the float a motor bracket to attach the spring.
WHN 11-01-2024 02:09 PM
I also agree. I like the way the brake pedal comes back and bangs against the floor board. You know they are disengaged. No drag, no question.
Enjoy
JayJay 11-01-2024 09:25 PM
2 Attachment(s)
See #3 above. I heated up the flat bar in the vise and twisted it to the proper angle. A few back-and-forth until I got the proper compound angle. I also had to use a longer bolt in the flywheel housing. I beveled/rounded the back edge of the gizmo to conform to the round clutch housing casting.
Fullraceflathead 11-02-2024 08:33 AM
Great idea and photos JayJay, thanks!!!
JohninKuranda 11-02-2024 09:46 PM
Many thanks for the responses. I am in the process of making a similar set up as suggested by JayJay!
