I want to adjust my valves but… I have 1000 miles on my car now. Fun summer! In anticipation for getting the interior done in January, I figured I’d clean up the firewall which meant removing the engine and addressing a couple of things. I have a minor oil leak so I’ll fix that but I also think a lifter or two is ticking as I think the adjustment is slightly off. This was my first flathead build. So with the engine out I want to readjust the valves.
Here’s my problem. How do I know which lifter I’m on to be adjusted without having the engine apart like it was when I set them and could see the cam? What am I overthinking? And yes, I used adjustable lifters! I’ve heard/seen of a round tool that attaches to the crank but I can’t seem to find where to buy it. Thanks! |
Re: I want to adjust my valves but… There aqre lots of ways, but this is mine. Pull plugs, rotate until #1 at tdc on compression. You will see that both valves are fully closed. If pulley isn't marked use a big end of a zip tie down the hole to feel for exact tdc. Now follow the firing order as you rotate to next one and next. Be careful not to over-use your wrench. Too much back and forth the lifter threads can get loose, and you know next time you'll be leaning over the fenders. Not fun. Good luck, it's satisfying getting those tickers silenced.
Re: I want to adjust my valves but… Here's a bunch of threads on how to adjust your adjustables.
https://www.fordbarn.com/forum/searc...rchid=41211252 Plus, take a look here: https://www.bing.com/search?q=how%20...&ghacc=0&ghpl= |
Re: I want to adjust my valves but… Do as GB wrote above its by far the easiest way to adjust valve's. Its exactly how i do it in all the engine's I build and run as well as our Ford flathead V-8's that go well over 200 MPH.
Ronnieroadster |
Re: I want to adjust my valves but… Quote:
Re: I want to adjust my valves but… When the piston is at TDC, both valves are within the base circle, or lowest point of the cam.
Re: I want to adjust my valves but… Just like everyone has said, when both lifters on the same cylinder are down all the way adjust the valves on that cylinder. It easy on flathead because you can see when both lifters have bottom out. I have a '66 GT-350 with a 289 and solid lifters. On that engine I have to use the harmonic balancer to adjust them, and they want them done hot, so I warm it up and remove one valve cover and do that side then put it back together warm it up again and then do the other side.
Re: I want to adjust my valves but… Here’s my method….
I-C-E. When the Intake Closes do the Exhaust (ICE) E-O-I. When the Exhaust Opens do the Intake (EOI) Easy to remember and it works! |
Re: I want to adjust my valves but… Thanks yall. What if I don’t want to remove my heads to see the valves?
Re: I want to adjust my valves but… What Denny is saying about watching the lifters is because they act directly against the valve's stem which you can also see once you pull the intake off to do the adjustment. It will all come back to you once you pull the intake. Think of it like an old volkswagon bus, but without all those crazy rocker arms and pushrods and such. Oh, and unlike the bus, you can stand in a normal upright position in your garage while you do the adjusting.
This video shows the holes many people drill in the lifter bores when they rebuild a flathead. If you're lucky your block will have them, if not you can still use the other tools shown. https://www.youtube.com/watch?v=KBN5SD8mPGU |
Re: I want to adjust my valves but… busmania: Here's the wrench for adjusting you adjustables.
https://www.cjponyparts.com/tappet-a...ent=Best%20COS |
Re: I want to adjust my valves but… If you don't have the drilled holes to hold the lifters from twisting, it can be a nasty job!
My experience and a modification I made to the "Johnson Tool" is shown in this post. https://www.fordbarn.com/forum/showp...6&postcount=40 I also made a couple of additional pin tools for the next time. https://www.fordbarn.com/forum/showp...2&postcount=54 Glenn |
Re: I want to adjust my valves but… use grease on the intake gasket so it can be reused a few times
Re: I want to adjust my valves but… busmania: glennpm's posting of his adjusting tools is "solid gold". Great advice.
