Connecting rod machined to take insert bearing ? I am still a little confused on this issue.
Can the standard B motor connecting rods be machined to take the insert bearings from Snyder ect. Most topics in the past seem to result in the babbit vs insert debate :D:D |
Re: Connecting rod machined to take insert bearing ? Not sure the bearings that Snyders sells
In the past B rods were machined for inserts using common auto bearings The basic assembly can fit a 2.000 bore or if careful 2.021 bore The old Volvo bearings worked well and I have two motors with them The 2.021 uses two narrowed inserts per rod What I see for the thrust control is some type of welding and machining to correct dimension IMHO there are new rods available properly made to use bearing inserts and replacement inserts available J |
Re: Connecting rod machined to take insert bearing ? This is from Snyder's web site.
"If you have already purchased a set of our new "B" style connecting rods, these are the replacement bearing kits that fit them. A set is enough to do 4 rods. 1932-34, 4 cylinder. NOTE: If boring out original rods to accept these bearings, the bore specification is 2.0210/2.0215". U.S.A." |
Re: Connecting rod machined to take insert bearing ? The new B rods are from Antique Engine Rebuilding @ $770 a set with bearings.
https://www.antiqueenginerebuilding....ting_rods.html If you have a good set of rods it will certainly be cheaper to bore them and just buy the bearings. |
Re: Connecting rod machined to take insert bearing ? 15 years ago, I had a diamond B engine rebuilt with insert bearings throughout. The mains were the same as Terry Burtz uses in his engine (2" journal) only mine are 0.010" undersize. The rods are (I think ) from a Toyota forklift. "EBR004H-010". Those inserts were put into machined original rods.
In short, to answer the question: YES original rods can be machined to take inserted bearings. |
Re: Connecting rod machined to take insert bearing ? Trust me
This is no simple machining process to be done correctly Lost count of how many sets done but it was enough to know the ins and out of the process I would cull about 25% of the candidates as junk and keep in mind the small end always gets a new set of bushings so it was not part of the criteria Just an informed opinion J |
Re: Connecting rod machined to take insert bearing ? Fatigue is a big consideration 90 years after they were made and who knows what abuse in the mean time.
Re: Connecting rod machined to take insert bearing ? Thank you for everyones input.It has sent me off on a google binge that seems to have no end. Never realized there were so many options.
