The Ford Barn
-   -   Carb leaks (https://www.fordbarn.com/forum/showthread.php?t=343182)
Habusailor 10-16-2024 06:58 PM
Carb leaks
What causes the carburetor to loose its fuel and needs priming to start, if it has not run for a week or two?
paul2748 10-16-2024 07:05 PM
Re: Carb leaks
Power valve
Kube 10-16-2024 07:29 PM
Re: Carb leaks
The fuel in the bowl can also evaporate. I pull the choke closed when I shut the engine down.
Most likely the power valve as has been advised.
Habusailor 10-17-2024 07:32 AM
Re: Carb leaks
Power valve thanks.
Kube 10-17-2024 08:01 AM
Re: Carb leaks
Originally Posted by Habusailor (Post 2344188)
Power valve thanks.
Be aware that many, perhaps most, new power valves will not seal as they are delivered. I believe most folks get a "good one" from Daytona.
1942deluxe 10-17-2024 08:09 AM
Re: Carb leaks
Mike, my 48 started hard when it sat for any extended period. I followed your advice about the choke and it now starts much easier! Thank you.
Planojc 10-17-2024 08:51 AM
Re: Carb leaks
This can happen even if the power valve is not leaking due to as Kube said, evaporation. Not 100% sure but it seems that the ethanol gas evaporates quicker than regular gas. That's why many add an electric fuel pump to prime the carb.
