The Ford Barn
-   -   Need Help to Identify Parts (https://www.fordbarn.com/forum/showthread.php?t=342457)
ford33 09-23-2024 03:49 PM
2 Attachment(s)
I have a few engine pans I don't know what they fit as well as a pair of trunk hinges
DavidG 09-24-2024 06:26 AM
Re: Need Help to Identify Parts
The engine splash pans in the first photo are post-'34s given the holes in the left side pans for the steering sector housing to pass through.
cas3 09-24-2024 09:52 AM
The hinges look like the deck lid for a 33-34 coupe or roadster
V8ER 09-24-2024 10:09 AM
The top brown one and the bottom row center gray one (which has been sawed through) are both '35-'36 left side engine pans.
Karl Wescott 09-24-2024 10:16 AM
Every 1933-34 trunk hinge (and 1935-36 for that matter) I have seen have been CAST, these are stamped two piece and welded together. The trunnions (body mounts) are also cast and use 4 mounting holes.
cas3 09-24-2024 10:21 AM
Good eye Karl, I did not notice they are stamped. The shape seems correct, reproduction's ?
ford33 09-24-2024 12:48 PM
2 Attachment(s)
Here are some better photos. 2 stacked pans identified as 35-36 left, thanks.. Could the trunk hinges be 37 coupe or 38 sedan? I had both as parts cars
Karl Wescott 09-28-2024 08:45 PM
Per a photo sent to me privately, It appears the hinge is 1937-38 Coupe, Club Coupe, or Club Convertible. (Not possible to rule out 1938 Standard sedan at this time). Another caveat is the op is from Canada as is the source of my reference photo, so there is an unlikely possibility of a Canada only variation.
ford33 09-30-2024 10:42 AM
Thanks for the help
