The Ford Barn
-   -   Marvel S. Carburaters (https://www.fordbarn.com/forum/showthread.php?t=342328)
Hoffman 09-20-2024 09:18 AM
Looking for member experiences before I buy. Alternate driven by current Zenith prices. Thanks.
DJ S 09-20-2024 09:20 AM
Re: Marvel S. Carburaters
Great carb…
-Better throttle response and power.
-Simpler than a Zenith.
-Typically Cheaper than other alternatives.
-Readily Available.
Goodie 09-20-2024 11:36 AM
I'll second that!
BVZ24 09-20-2024 11:43 AM
Switched to a marvel and probably will never go back for the reasons stated. It's also complimentary to my higher compression head.
Dick M 09-20-2024 11:59 AM
Here is where you can buy a freshly rebuilt Marvel at a very reasonable price. I have a Marvel purchased 10 years ago from Gary and it is still running strong.
MARVEL SHEMBLER CARBERATOR-----903-490-3725
976 COUNTRY ROAD [email protected]
Gary Johnston
TEXARKANA, TX 75503---------------CARBS/EXCELLENT WORK
mcgarrett 09-20-2024 01:06 PM
Marvel is an excellent carburetor; simple design, fewer parts, better performance, and repair parts are available at Renner's Corner...
https://rennerscorner.com/index.html.
A word of caution: The Marvel is made of pot metal just like the Tillotson. Be careful not to tighten the flange mounting bolts too tight. Many people have the tendency to tighten them like they would a Zenith, which is cast iron. Doing so can warp the mounting flange causing a vacuum leak. Keep them just tight enough to seal the gasket and no more.
alexiskai 09-20-2024 02:38 PM
The biggest downside of the Marvels, other than being not original equipment, is they are not as sturdily built as the Zenith, not nearly as comprehensively documented, and don't have as wide a base of parts vendors. Consequently more difficult to repair. But also very reliable, so you may not need to repair it for years.
Herb Concord Ca 09-20-2024 04:03 PM
Have a Marvel on both my A's, would never go back.
Fullraceflathead 09-21-2024 04:54 AM
Probably 1 of the best carburetors for the model A. side-by-side with the Simmons carburetor then next would be the tillotson and then the zenith the zenith is really an antiquated design that's why it suffers from performance compared to these other carburetors!!!
Aretino 09-21-2024 05:54 AM
Marvel Carb is my choice
rotorwrench 09-21-2024 05:28 PM
Marvel Schebler and Tillotson were both divisions of Borg Warner. Both were good aftermarket replacements for the old cast iron Zenith.
Model A Canuck 09-21-2024 08:55 PM
McDonald carb is a good source for Marvel carbs
www.mcdonaldcarb.com
Hoffman 09-21-2024 09:46 PM
Thanks, just checked and right now site doesn’t show any 2405 carbs, or parts.
hbrandon 09-26-2024 09:39 AM
Message from Gary Johnston yesterday and he advised he no longer does carbs. H Brandon
Dick M 09-27-2024 01:22 PM
So disappointed to hear Johnston no longer does carb work. His dad had the business before him. Unfortunately, his dad died from COVID and he was the carb guru.
Y-Blockhead 09-28-2024 04:40 PM
Maybe not original equipment, but sold at Ford dealers for a replacement for Zenith carburetors. Even had a Ford part # at one time.
RENNERS CORNER 03-18-2025 12:17 AM
Fact is the Marvel Schebler and the Tillotson were Ford authorized service replacements installed by Ford dealerships starting respectively in 1948 and 1950.
In fact, they even have Ford part numbers with Ford drawings.
They performed the same as or better than the original Zenith carburetor or Ford would not have endorsed them.
The problem is that some people are not capable of restoring them to the condition that they were when they were new, so they downplay them.
ALL of the parts for the Ford released Marvel Schebler are available today.
