The Ford Barn
-   -   21" Wheels (https://www.fordbarn.com/forum/showthread.php?t=341264)
rarebike 08-17-2024 07:51 PM
21" Wheels
I just picked up a set of four 21" Model A rims that the owner says are AR wheels, how do I positively identify them as AR wheels?
ronn 08-18-2024 06:54 AM
Re: 21" Wheels
By the depth of the inner rim. Its very apparent-thinner hub about 1 /14 inch deep vs about 1 3/4 inch deep.
just compare them to one you have laying around.
rotorwrench 08-18-2024 08:34 AM
Re: 21" Wheels
The design was a carry over from the 1926/27 model T with small drums. The early A drum size was larger and so was the wheel center but the T lug bolts were retained. When the brake system was improved with larger drums, the wheels was also changed to function with the new drums.
Model "A" Fords 08-18-2024 09:42 AM
Re: 21" Wheels
I know people associate "AR" as being an early Model "A" but I understood "AR" was part of a number/letter combination on a revised part and not actually referring to an early car.
"A" for model "A" and "R" for "Revised"?
We had a set of wheels that we thought were Model "T" but told they were "AR". The person buying them said they were early Model "A". I suppose they both meant the same thing.
rarebike 08-18-2024 11:50 AM
Re: 21" Wheels
2 Attachment(s)
I don't have another Model A wheel to compare to but this is what I have.
ronn 08-19-2024 08:37 AM
Re: 21" Wheels
rarebike, take a look at the back of the rim-hub-how deep is it?
thats your answer, not what youre showing.........
rarebike 08-19-2024 09:33 AM
Re: 21" Wheels
1 Attachment(s)
Is this what you are talking about?
ronn 08-19-2024 11:14 AM
Re: 21" Wheels
yes and that appears to be just a reg rim.
the AR should be 1 1/4 approx
dlshady 08-19-2024 08:33 PM
Re: 21" Wheels
Here's some photos I took a few years ago to help people ID their 21" wheels. The orange wheel is a Model T, the bare metal wheel is an Early 28 (or AR) and the red oxide primed wheel is the late 28-29 style.
Model T:
https://i.postimg.cc/g2kDVNtf/DSC05154.jpg
Early 28:
https://i.postimg.cc/G2YJLN9s/DSC05155.jpg
Late 28 and 29:
https://i.postimg.cc/0j0YmwYk/DSC05156.jpg
Model T on the left and Early 28 on the right:
https://i.postimg.cc/9Xdtsvv6/DSC05157.jpg
Early 28 on the left and Late 28-29 wheel on the right:
https://i.postimg.cc/k5Lvd9Mm/DSC05149.jpg
https://i.postimg.cc/BQJc3m3X/DSC05158.jpg
Jim/GA 08-19-2024 09:21 PM
Re: 21" Wheels
2 Attachment(s)
The Ford Service Bulletins discuss this (early wheel/drum versus later wheel/drum).
In June 1928 (with the separate parking brake system) the hub flange depth increased from 1-3/16” to 1-3/8”.
Mismatching either wheel to the wrong drum will be bad.
DougVieyra 08-20-2024 02:13 PM
Re: 21" Wheels
dlshady - Post # 9
If "A picture is worth a thousand words", you have given us the Encyclopedia Brittanica !
Many of us are more 'visual' than those who are 'literate'. And I appreciate both; but with your photos you have done us all a great service. Thank you very much.
- Doug Vieyra, Eureka, California
dlshady 08-20-2024 03:30 PM
Re: 21" Wheels
Originally Posted by DougVieyra (Post 2332046)
dlshady - Post # 9
Glad to help! I was really active here several years ago, long before life had other plans for me, and I used to see the wheel question come up at least once a week. One day I was working on my son's Model T when the UPS man brought the early 28 wheel pictured above, and I realized it was a good time to drag out the third version and take some pictures while I had the opportunity. Those photos have been shared soooooo many times now it's not even funny, but as you said, a lot of folks just need to see something for it to click. And it never hurts to have them side by side so the differences become more obvious.
rarebike 08-20-2024 07:13 PM
Re: 21" Wheels
I appreciate all of the responses and I second the "A picture worth a thousand words"
Tim in Omaha
Fullraceflathead 08-21-2024 06:38 AM
Re: 21" Wheels
That seems fairly simple to identify after seeing the pictures the late 28 and 29 will have a gradual radius whereas the early 1 doesn't!!!
