The Ford Barn
-   -   modern distributor (https://www.fordbarn.com/forum/showthread.php?t=340941)
midgetracer 08-06-2024 08:15 AM
modern distributor
What currently available distributor is best to use with a cast iron Miller OHV head? I believe that the cam is a Winfield grind. I have used a late model Mallory unit, but when I set the timing to run best at speed, the engine kicks back when trying to start. The advance kit for the Mallory is no longer available since Mallory became part of group.
Malibob 08-06-2024 08:39 AM
Re: modern distributor
Following
nkaminar 08-06-2024 12:58 PM
Can you use a mechanical advance, like the stock Model A? Or, you might try the automatic advance that sits in the valve chamber. I will see if I can google it and put some more information in this post.
See post #6 in this discussion: https://www.fordbarn.com/forum/showt...1307&showall=1
ModelA29 08-06-2024 01:44 PM
FSI Zipper. They can set the curve for high compression heads.
https://www.fsignitions.com/fsi-zipper-distributor
  • Custom advance curves available from 12-32 degrees.
  • 24 to 26 degrees automatic centrifugal advance @ 2,000rpms.
  • 16 to 18 degrees of centrifugal advance available for high compression Flat heads.
  • 32 degree advance @ 3,200 rpms available for Miller OHV.
johnneilson 08-06-2024 07:22 PM
Midgetracer
All of the Mallory distributors have centrifugal advance mechanisms
Yours needs adjustment to allow for starting/cranking timing to be closer to tdc
But try this do not turn on ignition until you have the motor cranking over then turn on ignition
This is old trick to using magneto with no advance
J
midgetracer 08-07-2024 11:43 AM
Thank you Model A29. I will call FSignitions soon. Price on the internet is a bit scary, but if it solves my problem it may be worth it.
John ..I have been using that old trick, but would like to make it work like it should.
