The Ford Barn
-   -   1936 center cap on hub cap artillery wheel (https://www.fordbarn.com/forum/showthread.php?t=340923)
Ohc Joe 08-05-2024 01:01 PM
Okay so on this 36 you have the big center cap what's the best way to remove the small center cap or can you even remove them I want to get these powder coated along with the wheels also I am in need of two smaller center caps if anybody has a pair
Thanks Joseph
I can pick up the caps in so cal from san diego to Santa Barbara if anyone is local also the low desert areas
TJ 08-05-2024 01:42 PM
Re: 1936 center cap on hub cap artillery wheel
To remove the small center cap you drill a small hole in the back of the big cap. Then used compressed air in the hole to blow off the small cap. Be sure to have some padding to catch the small cap. Powder coating the big cap may not be a good idea as the coating may be too thick to allow the small cap to be put back on.
Ohc Joe 08-05-2024 03:31 PM
Awesome
Thanks for the tip
Hopefully others might chime in on powder coating
Ohc Joe 08-06-2024 07:24 AM
Drilled a small hole slowly
Blew air
Poped right off
Just got to drill slow through the cap and not all the way through
Anyone have 2 caps for sale
tubman 08-06-2024 04:22 PM
4 Attachment(s)
Joe,
I have 3 random wide-5 hubcaps I'd let go cheap. I think they are '36 and '37,but am not sure (I'm an 8BA guy). Two have the v8 emblem impressed in, and one has it pressed out They are driver quality with minor scuffs, but one of is pretty nice with just a small scratch.
Let me know if they would help.
mercman from oz 08-06-2024 04:32 PM
https://www.fordbarn.com/forum/attac...p;d=1722979341
tubman, you are correct with your identifications
1936 Ford Hubcap
mercman from oz 08-06-2024 04:34 PM
1937 Ford Hubcap
Notice that the designs are the same on both Hubcaps.
However, it is recessed for 1936 and raised for 1937
mercman from oz 08-06-2024 04:36 PM
Check out this Thread, restoring a 1937 Ford Hubcap
https://www.fordbarn.com/forum/showt...ghlight=hubcap
tubman 08-12-2024 09:23 AM
3 Attachment(s)
Joe,
I popped the stainless from the first '36 cap. Here are some photos.
