The Ford Barn
-   -   Who is the authority on 150* Station Wagon bodies?? (https://www.fordbarn.com/forum/showthread.php?t=340564)
BRENT in 10-uh-C 07-23-2024 07:49 AM
With Tim passed on, who is now the knowledgeable person(s) on 150A or 150B bodies? More specifically regarding the plywood.
TIA
rotorwrench 07-24-2024 10:00 AM
Re: Who is the authority on 150* Station Wagon bodies??
These bodies were produced in such limited quantities that there are likely fewer model A specific builder now days. The woodie guys tend to offer service to any or all makes of station wagons. One outfit started out in furniture restorations but found a niche in car body restoration.
In aviation, when working with the old wood wing types, I've always gravitated toward the marine or aircraft grade poplar mahogany plywoods so I have no idea what other grades or types are out there commercially. You likely have more information about the model A types than most folks do now.
Karl Wescott 07-24-2024 01:27 PM
Everything you wanted to know about wood but were afraid to ask: https://www.fpl.fs.usda.gov/documnts...fpl_gtr190.pdf
fordfarm 07-25-2024 02:18 PM
Hi Brent I am a long time member of the Woody Wagons. I finished my wagon in 1986 and Tim helped in printing the original Ford mylar drawings. I used 9ply i/2 inch birch plywood. That plywood is used in fine cabinetry. It comes from Finland and is in 5x5 feet sheets. Very nice to work with. There maybe orther countries that produce that fine plywood. That plywood is a A panel on both sides. May be plugged on one side so you would have to work around that. Hope that helps. John
1928FordGuy 08-10-2024 10:48 PM
I guess that the question remains unanswered...
