The Ford Barn
-   -   Recommended sparkplug (https://www.fordbarn.com/forum/showthread.php?t=340303)
Rockymountainsparky 07-13-2024 08:30 PM
I'm converting my 36 3 window coupe to 12 volt and changing the ignition to an electronic distributor. This is the original 21 stud V8. Any recommendations on the sparkplug?
Jumbogem29 07-13-2024 08:40 PM
Re: Recommended sparkplug
NGK B6L works for me no probles
tubman 07-13-2024 09:11 PM
Use what you have; spark plugs are not voltage sensitive. Especially not to the primary voltage.
Rockymountainsparky 07-14-2024 01:39 PM
Thanks! I didn't know if the electronic ignition was going to make a difference.
