The Ford Barn
-   -   1934 steering box educate me before i dig in? (https://www.fordbarn.com/forum/showthread.php?t=340288)
sawzall 07-13-2024 11:22 AM
so I have a 34 wagon, non running (im working on fitting the wood)
a few days ago i moved it and during that process i "lost" steering.. IE all the sudden the steering wheel lost ability to turn the wheel.
I know I am going to need to pull the box, what typically fails in these early boxes? ive only ever owned 40 and later boxes, (and one model a box) and I have NEVER taken one apart.
i found a exploded view of the box over on the hamb.. assuming this is correct
what are the first things to look at?
https://www.jalopyjournal.com/forum/...1-jpg.4258800/
fordyford 07-13-2024 11:45 AM
Re: 1934 steering box educate me before i dig in?
May be as simple as a missing or damaged key in the steering wheel to shaft connection.
Newc 07-13-2024 11:45 AM
All local V8ers use Greg Edwards here in Oregon . He is a member of RG #10 and in the roster. A master machinist and gear box rebuilder. 503-357-3980 Newc
petehoovie 07-13-2024 11:47 AM
Charlie Stephens 07-13-2024 02:12 PM
I wonder if the previous owner forgot the woodruff key for the steering wheel and it finally came loose? Maybe the worm came off of the shaft? Just a bit of trivia. The steering box looks like a '32 but the bolt pattern where it bolts to the frame is clocked different. If you are looking for parts be sure to get the right ones.
Charlie Stephens
jimTN 07-13-2024 04:22 PM
If the lock is not engauged, and there is no play, side to side in the gear, then something is jammed in the gear which would be very unusual. Have you eliminated the lock being engauged?
Charlie Stephens 07-13-2024 04:31 PM
When you say "lost steering" do you mean you can turn the wheel and nothing happened or do you mean you can't turn the steering wheel?
Charlie Stephens
