The Ford Barn
-   -   Tail light & Cowl Light pigtails (https://www.fordbarn.com/forum/showthread.php?t=339462)
31 Woody 06-16-2024 06:49 PM
The tail light and cowl light pigtails both show as out of stock at Brattons and Snyders—does anyone know who may have them available?
Bigsnapper43 06-16-2024 07:57 PM
Re: Tail light & Cowl Light pigtails
Give me a call.740 658 3495
nkaminar 06-17-2024 06:27 AM
Unless you are going to be taking your electrical system apart, the modern crimp connectors will work great, especially the ones with the heat shrink tubing built in. The crimping, if done with the ratchet type crimper, will produce an air and water tight connection at the crimp. Although they will not pass a 100 point inspection.
